Supla 2 persianas
elmaya
Modulo para controlar 2 persianas con memoria de posición.
Gpio:
relay_1 = GPIO 5 /D1 -- R1 down
relay_2 = GPIO 4 /D2 -- R1 up
relay_3 = GPIO 14/D5 -- Rs2 down
relay_4 = GPIO 12/D12-- Rs2 up
btn_1 = GPIO 2 /D4 -- Rs1 up
btn_2 = GPIO 3 /RX -- Rs1 down
btn_3 = GPIO 15 /D8 -- Rs2 up
btn_4 = GPIO 13 /D7 -- Rs2 down
led = GPIO 0 /D3
#include <FS.h>       // ---- esp board manager 2.4.2 --- iwip Variant V2 higher Bandwidth
#include <ESP8266WiFi.h>
#define SUPLADEVICE_CPP  // ----- V 1.6
#include "SuplaDevice.h"
#include <ESP8266WebServer.h>
#include <DNSServer.h>
#include <WiFiManager.h> //--------- https://github.com/tzapu/WiFiManager/tree/0.14 -------------
#include <ArduinoJson.h> //--------- https://github.com/bblanchon/ArduinoJson/tree/v5.13.2 ------
#include <EEPROM.h>
#include <DoubleResetDetector.h>
#include <Ticker.h>
#include <ESP8266HTTPUpdateServer.h>
extern "C"
#include "user_interface.h"
//#define D0 16  //no internal pullup resistor
//#define D1  5
//#define D2  4
//#define D3  0  //must not be pulled low during power on/reset, toggles value during boot
//#define D4  2  //must not be pulled low during power on/reset, toggles value during boot
//#define D5 14
//#define D6 12
//#define D7 13
//#define D8 15  //must not be pulled high during power on/reset
Ticker ticker;
#define relay_1 5
#define relay_2 4
#define relay_3 14
#define relay_4 12
#define btn_1 2
#define btn_2 3
#define btn_3 15
#define btn_4 13
#define status_led 0
#define DRD_TIMEOUT 3 // Number of seconds after reset during which a  subseqent reset will be considered a double reset.
#define DRD_ADDRESS 0
DoubleResetDetector drd(DRD_TIMEOUT, DRD_ADDRESS);
bool pr_wifi = true;
int s;
unsigned long wifi_checkDelay = 60000;
unsigned long wifimilis;
bool tikOn = false;
int inttmp0 = -1;
bool savers0 = false;
int inttmp1 = -1;
bool savers1 = false;
int Sp = -1;
char Supla_server[60];
char Location_id[15];
char Location_Pass[20];
char Supla_name[51];
char update_path[21];
char update_username[21];
char update_password[21];
byte mac[6];
bool shouldSaveConfig = false;
bool initialConfig = false;
int timeout  = 300;
WiFiClient client;
ESP8266WebServer httpServer(81);
ESP8266HTTPUpdateServer httpUpdater;
void supla_rs_SavePosition(int channelNumber, int position) {
          switch(channelNumber)
   case 0:
    if ((!digitalRead(relay_1))&&(!digitalRead(relay_2))){ // save if stopped
      inttmp0 = position;
      savers0 = true;
    if (position <= 100 || position >= 10100){ // save in limit position
      inttmp0 = position;
      savers0 = true;
    break;
   case 1:
    if ((!digitalRead(relay_3))&&(!digitalRead(relay_4))){ // save if stopped
      inttmp1 = position;
      savers1 = true;
      inttmp1 = position;
      savers1 = true;
   break;
void supla_rs_LoadPosition(int channelNumber, int *position) {
   case 0:
      EEPROM.get(1, *position);
      Serial.print("read position R1: ");
      Serial.println(*position);
    break;
    case 1:
      EEPROM.get(11, *position);
      Serial.print("read position R2: ");
    break;
void supla_rs_SaveSettings(int channelNumber, unsigned int full_opening_time, unsigned int full_closing_time) {
   case 0:
       EEPROM.put(50, full_opening_time);
       Serial.println("R1 full opening time Saved");
       EEPROM.put(55, full_closing_time);
       Serial.println("R2 full closing time Saved");
       EEPROM.commit();
  break;
  case 1:
       EEPROM.put(60, full_opening_time);
       Serial.println("R2 full opening time Saved");
       EEPROM.put(65, full_closing_time);
       EEPROM.commit();
  break;
void supla_rs_LoadSettings(int channelNumber, unsigned int *full_opening_time, unsigned int *full_closing_time) {
  case 0:
    EEPROM.get(50, *full_opening_time);
    EEPROM.get(55, *full_closing_time);
    Serial.print("read R1--channel: ");Serial.print((channelNumber));Serial.print(" opening_time ");Serial.print((*full_opening_time));Serial.print(" closing_time ");Serial.println((*full_closing_time));
  break;
  case 1:
    EEPROM.get(60, *full_opening_time);
    EEPROM.get(65, *full_closing_time);
    Serial.print("read R2--channel: ");Serial.print((channelNumber));Serial.print(" opening_time ");Serial.print((*full_opening_time));Serial.print(" closing_time ");Serial.println((*full_closing_time));
  break;
void tick(){
  int state = digitalRead(status_led);
  digitalWrite(status_led, !state);
void saveConfigCallback () {
  Serial.println("Should save config");
  shouldSaveConfig = true;
void ondemandwifiCallback () {
  ticker.attach(0.2, tick);
  WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 60);
  WiFiManagerParameter custom_Location_id("ID", "Location_id", Location_id, 15);
  WiFiManagerParameter custom_Location_Pass("Password", "Location_Pass", Location_Pass, 20);
  WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51,"required");
  WiFiManagerParameter custom_update_path("updatePath", "update path", update_path, 21,"required");
  WiFiManagerParameter custom_update_username("updateUsername", "update username", update_username, 21,"required");
  WiFiManagerParameter custom_update_password("updatePassword", "update password", update_password, 21,"required");
  WiFiManager wifiManager;
  wifiManager.setBreakAfterConfig(true);
  wifiManager.setSaveConfigCallback(saveConfigCallback);
  wifiManager.addParameter(&custom_Supla_server);
  wifiManager.addParameter(&custom_Location_id);
  wifiManager.addParameter(&custom_Location_Pass);
  wifiManager.addParameter(&custom_Supla_name);
  wifiManager.addParameter(&custom_update_path);
  wifiManager.addParameter(&custom_update_username);
  wifiManager.addParameter(&custom_update_password);
  wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
  wifiManager.setMinimumSignalQuality();
    wifiManager.setConfigPortalTimeout(timeout);
    if (!wifiManager.startConfigPortal("Supla R2")) {
     Serial.println("Not connected to WiFi but continuing anyway.");
    } else {
      Serial.println("connected...yeey :)");    //if you get here you have connected to the WiFi
    strcpy(Supla_server, custom_Supla_server.getValue());
    strcpy(Location_id, custom_Location_id.getValue());
    strcpy(Location_Pass, custom_Location_Pass.getValue());
    strcpy(Supla_name, custom_Supla_name.getValue());
    strcpy(update_path, custom_update_path.getValue());
    strcpy(update_username, custom_update_username.getValue());
    strcpy(update_password, custom_update_password.getValue());
    if (shouldSaveConfig) {
    Serial.println("saving config");
    DynamicJsonBuffer jsonBuffer;
    JsonObject& json = jsonBuffer.createObject();
    json["Supla_server"] = Supla_server;
    json["Location_id"] = Location_id;
    json["Location_Pass"] = Location_Pass;
    json["Supla_name"] = Supla_name;
    json["update_path"] = update_path;
    json["update_username"] = update_username;
    json["update_password"] = update_password;
    File configFile = SPIFFS.open("/configV2.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
    json.prettyPrintTo(Serial);
    json.printTo(configFile);
    configFile.close();
    Serial.println("config saved");
    WiFi.softAPdisconnect(true);   //  close AP
    WiFi.mode(WIFI_STA);
    ticker.detach();
    digitalWrite(status_led, HIGH);
    ESP.restart();
    delay(5000);
void status_func(int status, const char *msg) {
 s=status;
void setup() {  //------------------------------------------------ Setup ----------------------------------------------
  wifi_set_sleep_type(NONE_SLEEP_T);
  EEPROM.begin(512);
  Serial.begin(115200);
  SPIFFS.begin();
  pinMode(status_led,OUTPUT);
  ticker.attach(0.8, tick);
  if (WiFi.SSID()==""){initialConfig = true;}
    Serial.println("mounting Fs...");
    if (SPIFFS.exists("/configV2.json")) {
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/configV2.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        size_t size = configFile.size();
        std::unique_ptr<char[]> buf(new char[size]);
        configFile.readBytes(buf.get(), size);
        JsonObject& json = jsonBuffer.parseObject(buf.get());
        json.printTo(Serial);   //print config data to serial on startup
        if (json.success()) {
          Serial.println("\nparsed json");
          strcpy(Supla_server, json["Supla_server"]);
          strcpy(Location_id, json["Location_id"]);
          strcpy(Location_Pass, json["Location_Pass"]);
          strcpy(Supla_name, json["Supla_name"]);
          strcpy(update_path, json["update_path"]);
          strcpy(update_username, json["update_username"]);
          strcpy(update_password, json["update_password"]);
        } else {
          Serial.println("failed to load json config");
  if (drd.detectDoubleReset()) {
    Serial.println("Double Reset Detected");
    ondemandwifiCallback ();
  } else {
    Serial.println("No Double Reset Detected");
   uint8_t mac[WL_MAC_ADDR_LENGTH];
   WiFi.macAddress(mac);
   char GUID[SUPLA_GUID_SIZE] = {mac[WL_MAC_ADDR_LENGTH - 3], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 3],
                                 mac[WL_MAC_ADDR_LENGTH - 2], mac[WL_MAC_ADDR_LENGTH - 0], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 2],
                                 mac[WL_MAC_ADDR_LENGTH - 3], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 3]};
  SuplaDevice.addRollerShutterRelays(relay_1, relay_2, false);
  SuplaDevice.addRollerShutterRelays(relay_3, relay_4, false);
  SuplaDevice.setRollerShutterButtons(0, btn_1, btn_2);
  SuplaDevice.setRollerShutterButtons(1, btn_3, btn_4);
  SuplaDevice.setStatusFuncImpl(&status_func);
  SuplaDevice.setRollerShutterFuncImpl(&supla_rs_SavePosition, &supla_rs_LoadPosition, &supla_rs_SaveSettings, &supla_rs_LoadSettings);
  SuplaDevice.setName(Supla_name);
  int LocationID = atoi(Location_id);
                    Supla_server,      // SUPLA server address
                    LocationID,        // Location ID
                    Location_Pass);    // Location Password
void loop() {
  drd.loop();
  if (initialConfig){
    ondemandwifiCallback () ;
      if (savers0){
       Serial.print("write position R1:");
       Serial.println(inttmp0);
       EEPROM.put(1, inttmp0);
       EEPROM.commit();
       savers0 = false;
      if (savers1){
       Serial.print("write position R2:");
       Serial.println(inttmp1);
       EEPROM.put(11, inttmp1);
       EEPROM.commit();
       savers1 = false;
  if (WiFi.status() != WL_CONNECTED) {
    WiFi_up();
    pr_wifi = true;
  else if ((WiFi.status() == WL_CONNECTED)  && (pr_wifi)){
    Serial.println("");
    Serial.println("CONNECTED");
    Serial.print("local IP: ");
    Serial.print("subnetMask: ");
    Serial.print("gatewayIP: ");
    long rssi = WiFi.RSSI();
    Serial.print("Signal Strength (RSSI): ");
    Serial.print(rssi);
    Serial.println(" dBm");
    pr_wifi = false;
    httpUpdater.setup(&httpServer, update_path, update_username, update_password);
    httpServer.begin();
  SuplaDevice.iterate();
  delay(25);
  httpServer.handleClient();
  if (s == 17){      // -----     STATUS_REGISTERED_AND_READY
      if (tikOn){
      ticker.detach();
      tikOn = false;}
  }else if (!tikOn){
      tikOn = true;
  if (Sp != s){
      Serial.print("Supla State: ");
      Serial.println(s);
      Sp = s;
// Supla.org ethernet layer
        if ( size > 0 ) {
        return -1;
          return client.connected();
         client.stop();
          SuplaDeviceCallbacks cb;
          cb.get_temperature = NULL;
          cb.get_rgbw_value = NULL;
          cb.set_rgbw_value = NULL;
          return cb;
void WiFi_up(){ // conect to wifi
 unsigned long ahora = millis();
  if (ahora >= wifimilis)  {
  Serial.println("CONNECTING WIFI");
  WiFi.begin();
  wifimilis = (millis() + wifi_checkDelay) ;
Configuración:
Inicie sesión en https://cloud.supla.org (el registro es gratuito).
Para acceder a la configuración WiFi es necesario pulsar Reset dos veces seguidas (esto ocurre automáticamente en el primer inicio después de programar el ESP8266).
El ESP8266 emitirá una Red WiFi con el nombre “Supla R2” conecte a esta Red.
En caso de que el navegador no abra automáticamente, ábralo y acceda a la página http://192.168.4.1.
Pulse en "Configure WiFi"
Seleccione su Red WiFi de la lista en la parte superior pulsando sobre la que corresponda.
"Password" Escriba la contraseña de su Red WiFi.
Rellene los campos con los datos de su registro en https://cloud.supla.org.
“Supla Device Name” será el nombre con el que identifique el dispositivo en la nube (útil cuando hay más de un dispositivo) por ejemplo “Persianas Salón”.
“Supla Last Sate” solo es informativo.
Pulsamos en “Save” y hemos terminado la configuración.
supla_R2D_DOUT_16Mbit.rar
zilhos
Excelente @elmaya muy buen trabajo
Muchas gracias
elmaya
Actualizada la descarga del primer post.
He añadido la actualización de la posición de las persianas en la App después de la perdida de conexión con el servidor Supla.
Útil si se mueven las persianas mientras no está conectado al servidor Supla para que muestre siempre la posición correcta.
zilhos
Hola @elmaya como siempre haces un trabajo genial
te queria preguntar si hay una version del ""pir supla telegram"" que funcione.
Probe todas las versiones del foro y nada, no funcionan
Desde ya Muchas Gracias !!
tecnica1
Hola @elmaya excelente, trabajo.
Ya hace un tiempo que lo ví, recién ahora lo implementé.
Me funcionó tanto la versión para cargar dede el IDE de Arduino, como el archivo compilado.
En función del Hardware que tengo, hice una modificacón de pines sin problema.
Pero necesito, si se puede, que el mismo dispositivo tenga Solo 1 PERSIANA y 1 VENTILADOR (o INTERRUPTOR DE LUZ).
Esto último no se como hacerlo, me podrás ayudar?
Si es así, necesito el archivo para poder editar los pines en caso de ser necesario.
De antemano muchas Gracias.
elmaya
Estos días estoy un poco estresado, en cuanto tenga algo de tiempo libre lo hago. ;)
tecnica1
Gracias, espero que hayas pasado una hermosa Navidad.
Maniek913
Hola
Tengo un problema con este soft:
1. Los botones D4 y D8 no funcionan
2. durante el reset, las salidas D5 y D6 se activan brevemente
3. El led de configuración funciona en el puerto D4 en lugar de D3
4. el modo de configuración se inicia después de la primera pulsación de reiniciar
Todo funciona bien con la aplicación.
¿Alguien ha comprobado este sistema? ¿Es solo un problema?
Lo probé en 3 tipos diferentes de mosaicos, con el mismo resultado.
El pin D8 no se puede utilizar como entrada
elmaya
¿Qué tipo de relé usas?
A D8 no le puedes conectar resistencia pullup externa.
Maniek913
Utilizo el mismo diseño que en la imagen: Wemos.
Pero es lo mismo en los otros módulos.
No conecté pul-ups, conecté el circuito como se muestra.
Return to “Ideas y conceptos”
