Smart dimmer and 2 way module
Post Reply
Kevphelanelec
Can someone give me advice on the 2 way module?
I connected the smart dimmer and can control the light fine but when I connect the 2 way circuit and module at the other switch the smart dimmer seems to power down and disconnects from the app
Tia
Kev.
Contact:
Please describe what exactly the dimmer is about. Manufacturer / Model.
Kevphelanelec
I had wired the dimmer wrong.
Both units require a permanent live which seems obvious now.
I fitted Jqs101w and jqs1w varilight smart dimmer and slave module
Thanks for the reply. Hopefully this will help someone in the future
Varilight_MB
I'm glad the issue was resolved.
Both Supla master and supplementary controller require live connection.
I would like to use this opportunity to clarify part numbers:
Varilight Supla master - JQSM101W
Varilight Supplementary controller - JQS1W
Varilight Technical
Kevphelanelec
Yes that's correct 👍🏻
Post Reply
Return to “Help”
