problem WIFI zamel row 02
Post Reply
claudio
Hello, I bought zamel row 02 which works very well, but now I have switched to EOLO with the Fritz router! Box 7530 and I can no longer connect via wifi, can you help me? thanks.
Contact:
You can fix it in 3 possible ways.
1 - Switch the module to the configuration mode and add it again from the application level
2 - Put the module into configuration mode. Then connect to his wifi network and change the settings on page http://192.168.4.1
3 - Change the name and password of the wifi in the new router to the same as in the previous one.
Post Reply
Return to “Help”
