Read command from server esp8266
Post Reply
micdj
Hello, thank you for your work, I realize persianas project simply, now I've a problem, how can I read command from supla server?, for example if I switch on the lamp on channel 0, how can I use this class
void SuplaDeviceClass::channelValueChanged(int channel_number, char v, double d, char var)
to read channel number, and value?
I try to insert
void channelvalue(int channel_number, char v, double d, char var)
SuplaDevice.setStatusFuncImpl(&channelvalue);
or
SuplaDevice.setTimerFuncImpl(&channelvalue);
Thank you
Contact:
Use a newer version of the library
https://github.com/SUPLA/arduino/tree/develop
micdj
Hello! thank you for answer!
I will try to understand, but library is very different.
I hope someone can help me.
Contact:
Do not use an old library that will be retired.
micdj wrote: Wed Jan 06, 2021 11:06 am Hello! thank you for answer!
Could you please elaborate a little bit more what you want to achive?
Post Reply
Return to “General discussion”
